LabWindows/CVI
Problem regarding NIDAQmx on labwindows
Hi all, I am using NI PCI-6251 multifunction Daq card on Labwindows. The attached program generates two waveforms from analog output channels 0 and 1. First i have to configure the desired amplitude, frequency and Rate on the panel and then press the start button. After pressing the start button if i attempt to change the amplitude or frequency, it doesn't change. I want to control the amplitude , frequency and rate in real time. Please edit the attached program in such a way that every control on the panel has a real time effect after the start button is pressed. Any help will be greatly appreciated.
(3,882 Views)
Here is the attached file.
(3,880 Views)
I am sorry for multiple posts,due to some problems in attachment.
(3,877 Views)
Hi mhs100,
I still cannot see any attachments.
S. Eren BALCI
IMESTEK
(3,862 Views)
Now finally here it is
(3,851 Views)
Please anyone else reply.
(3,833 Views)
