LabWindows/CVI
Problem using driver with the 6031A Agilent power supply
Hello and goodmorning,
I was trying to develop my first cvi application in wich i need to use a power supply (model Agilent 6031A). I first use direct GPIB command and i manage to make it work but with some trouble, due to the fact that sometimes the commands are missed.
So i have downloaded the driver, from the NI site, and i was trying to implementing it in my code. I found a problem with the very first instruction, the init one. Below are my code:
ViPSession InstrumentH;
... Appoggio=hp6xxxa_init ("GPIB0::5::INSTR", VI_ON, VI_ON, 1, &InstrumentH);
 After the above code was executed i found in "Appoggio" the value "-1073807339"  and InstrumentH is equal to NULL.
Any idea and advice would be very appreciated.
P.S.
There is a way, like in Labview, to find the explanation of the Error Code?
(3,389 Views)
Accepted by topic author FM82
Found the problem. The power supply must be switched from SCPI commands to the old ARPS commands using "SYST:LANG"
(3,364 Views)
