Hi there,
I'm evaluating CVI 8.1 and I found out a problem with the new disk-kit distribution procedure.
When you add a subfolder under the "application directory", it is assumed with absolute path I could not found the possibility to make it relative to the "application directory".
Here is an example:
[Program Files]
My AppDir
SubFolder1
SubFolder2
When the user, during the installation, changes the destination folder of the program (assume the user selects "C:\My App Dir"), the files (normally the .EXE and the .UIR files) are installed in the specified directory, but the subfolder (SubFolder1 and SubFolder2) and their files and copied under "[Program Files]\My App Dir".
Nonetheless, If I no not add any file to the subfolder, it is neither created. To solve the latest, I usually add a fake file...
Sometimes, the distribute kit procedure hangs up, especially during registry managing.
When CVI 8.1 patch is supposed to be released ?
Marco
