LabWindows/CVI
Problem with Stanford Ds345 to use Arbitrary generation
Good morning, i'm an italian student of Electronic Enginner second degree, i use DS345 to generate an arbitrary waveform but my program generate in the istrument every time an error about loading, i post my program:
double array[1000];
 int array1[1000],Instrument0;
// Arbitrary waveform generate by me
  Chirp(1000,amp,20,100,array);
// star to communicate with instrument
srds345_init ("GPIB0::10::INSTR", VI_TRUE, VI_TRUE, &Instrument0);
// convert array to int array1
  for(i=0;i<1000;i++){
array1[i]=(int)array[i];
sum+=array1[i];
// add checksum
array1[1000]=sum;
status=srds345_WriteInstrData(Instrument0, "LDWF?0,1000");
srds345_ReadInstrData(Instrument0,45,resp1,&b1);
SetCtrlVal(PANEL_2,PANEL_2_IDD,resp1);
srds345_WriteInstrData(Instrument0,(char*)array1);
 srds345_WriteInstrData(Instrument0,"FUNC5");
i don't know whre the error is....
Thank u for the the help....
(3,507 Views)
You need to increase the size of array1 so that you can add the sum value.  You are using array1[1000], but this array is 1000 entries long using index 0-999.  Accessing array1[1000] will generate a memory fault.
Message Edited by mvr on 11-27-2007 12:54 PM
(3,493 Views)
Excuse me i have made an error in that line, i have corrected it in my program but i have the same problem. I add the checksum as the last value but i can't send the array1 to DS345 because i recevied an error answer from the instrument. I have tried with the program in the DS345's manual but it doesn't work...why?
(3,489 Views)
