LabWindows/CVI
Problem with THD+N from HarmonicAnalyzer
I have saved the screenshot of the document in a .jpg file.
From my point of view Harmonic Analyzer Using Signal is giving a perfect result.
But I am really curious about the result given by that instrument.
It seems that the sampling rate is OK.  And I think you can get a better result if the number of samples covers exactly n periods of the square wave, like 262000 samples. But I don’t think the error coud be that large since you have sampled more than 1000 periods.
And have you used any window to avoid spectrum leakage?
Joyce
Message 11 of 15
(1,599 Views)
Hi, thanks a lot.
I wil check the operation of equipmen later.
I have ever try to set the samples to be n periods and use window, but it didn't work well.
And with using window, it will get error when the input is simple sanewave.
Are there other places where I may make mistakes?
Message 12 of 15
(1,577 Views)
I make the test with different input size which are 262000 and 262144. The results of THD are the same, but a little diference in THD+N.
With the window, the THD becomes lower.
Message 13 of 15
(1,554 Views)
What kind of window are you using?
Could you please try Hanning window?
Joyce
Message 14 of 15
(1,549 Views)
I have try Hanning window, but it make the result lower than 48%.
Thanks for your patient very much
Message 15 of 15
(1,538 Views)
