LabWindows/CVI
Problem with application name
Hi ! I've created the distribution kit of an application. Now, after modifying it, I changed the name (from 1.0 to 2.0) in "Build -> Target settings" and I changed the installation path too. But when I try to install the new version, it uninstall the older version first. Why ?
Thank you
(3,242 Views)
You should find useful information in this discussion [broken link removed]
(3,242 Views)
Thanks !!
(3,242 Views)
