LabWindows/CVI
Problem with calling Kernel32 function "Sleep()"
Hi there
I cannot seem to get this to work. In LabWindows I want to be able to call the Sleep function.
But when I #Include "Windows.h" I get errors that it cannot build:
"Redeclearation of 'CVI_GetFileSize' previous declared at utility.h:249"
The error stems from Winbase.h, which is included in Windows.h. The relevant
lines in Winbase.h is:
WINBASEAPI
DWORD
WINAPI
GetFileSize(
HANDLE hFile,
LPDWORD lpFileSizeHigh
Anybody had this error. Utility.h is a header that is included for other
function vital to Labwindows and it seems odd to me that there is
declaration overlap.....
Klaus
(4,097 Views)
Hello
Make sure you include windows.h as the very first header in your header section.
Hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(4,094 Views)
Thanks Bilal
That worked like a charm 🙂
Klaus
(4,094 Views)
A tip for anyone else trying to implement sleep().  If the include windows.h generates compiler errors, you can also try basicsdk.h.
This will give you sleep() functionality without all the extra declarations that can cause problems with CVI.
(3,961 Views)
