LabWindows/CVI
Problem with char 3D Array... C-Guru wanted !
I would like to define a 3D char Array global.But I dont want to define the Array static,
the Array Size should be defined through a function.
How can I do it ? Please help..
For a code example, I would be really happy.Thanks a lot !!!
//So I dont want it anymore :
#include
#define x 10
#define y 10
#define z 10
static char Data[x][y][z];//static declaration
void Print(void);
void main (void){
strcpy(Data[0][2],"Hello");
Print();
void Print (void)
printf("%s\n",Data[0][2]);
/* Dont work... : (
#include
static int *Data;
void Print(void);
int Define(int,int,int);
void main (void){
Data = Define(10,10,10);
strcpy(*Data[0][2
],"Hello");
Print();
void Print (void)
printf("%s\n",*Data[0][2]);
int Define (int x,int y,int z)
static char Array[x][y][z];
return &Array[0][0][0];
(3,190 Views)
/* in ANSI C, you may do as follows */
#include "alloc.h"
char ***Data;
void allocate(int x,int y,int z);
int i,j;
Data=(char ***)malloc(x*sizeof(char **));
for(i=0;i Data[i]=(char **)malloc(y*sizeof(char *));
for(j=0;j Data[i][j]=(char *)malloc(z*sizeof(char));
/* I have not tested it yet though. */
(3,190 Views)
thanks!
(3,190 Views)
