LabWindows/CVI
Problem with connecting to NI USB6008 with LabWindows
Hi everybody,
I am making a program in LabWindows and so far I have got two instruments running without any problems. But I am trying to add an NI USB6008 to the program. I have downloaded something called "NIDAQmxBase" and added a file called "NIDAQmxBase.h" but I can´t find the ".fp" file and therefore I have no functions to communicate with the instrument.
Can anyone help me?
(5,387 Views)
Why DAQmx base? Are you using Linux? For Windows, you should install DAQmx and refer to the shipping examples.
(5,377 Views)
I also tried DAQmx, but I read something on this forum about that one should use DAQmxbase for LabWindows.
But  either way, DAQmx or DAQmxbase, I can´t find this funtion panel ".pf " file. I only find a " .lib " file.
I need this ".fp" file to find the functions and initialize and control the DAQ.
DANBKM
(5,364 Views)
And I am running Windows 8.1
(5,363 Views)
Accepted by topic author DANBKM
The 6008 definitely can use DAQmx.
Regardless the chouce about the daqmx package to install, you must install it AFTER CVI has been installed, and in the installation process you must indicate to install support for that development environment.
After that, you should see daq function inside the Library menu (if the corresponding item is dimmed, go to Library >> Customize, mark the corresponding checkbox, press OK  and restart CVI to see the menu populated with data acquisition functions).
(5,348 Views)
If you actually read somewhere that you should use base with CVI, you need to post a link. With such a basic device, it may not matter which driver you use but base does not support all functions.
(5,343 Views)
I found it in library.
Problem solved. Thank you for your help!
(5,329 Views)
