LabWindows/CVI
Problem with distribution installer setup file
I have a program created on my developer pc. It runs very nice without any issues.
I want this program to be installed on a target machine, so I created a distribution installer.
The release configuration is set to "All configurations".
In the installer I set the Minimum operating system version to WindowsXP
I build the installer  on my pc without problems. I even run the installer and the program is installed on my pc with no issues.
But when I try to install it on the target machine I get the following message:
"Setup.exe is not a valid Win32 program"
What can be the reason for this ??
Message 1 of 10
(7,074 Views)
Hey MikaelD,
On the web there seems to be many different possible reasons:
- Corrupted .EXE, incomplete "download" (I'd imagine copy), CD drivers problems
- File not designed for your Windows OS
If you haven't already, I'd suggest you rebuild your application and redeploy it with a different CD/USB (it's worth a shot!) And make sure you're building from LabVIEW 32-bit? (I imagine WindowsXP machine is 32 not 64)
Message 2 of 10
(6,793 Views)
Thank you A-Guz-Man,
I’ll give it a shot!
MikaelD
Message 3 of 10
(6,789 Views)
A pleasure MikaelD!
A few other ideas I got from the web:
Other info that might be useful:
  • Does this happen when you install other programs locally? From an external drive (USB/DVD/CD)?
  • What is the LV version of the development environment?
Message 4 of 10
(6,785 Views)
@A-Guz-Man wrote:
A pleasure MikaelD!
I have seen this before a couple of times when trying to run an installation on a target machine
I use Labview 2020 proffesional
MikaelD
Message 5 of 10
(6,779 Views)
I haven't tried your procedure to build a Windows XP application from LabVIEW 2020 (and I assume Windows 10). I see a few potential risks but you might prove me wrong:
From the compatibility chart, it seems LabVIEW 2015 SP1 is the latest LV compatible application that can run on Windows XP SP3.
And from my LabVIEW 2020, I don't see the option to have a minimum Windows XP supported OS (which makes sense because LV 2020 is supported from Windows 7 onwards)
Sounds like you'd need to build the application from an older LabVIEW version that supports LabVIEW 2015 deployment (and thus Windows XP running)
Message 6 of 10
(6,774 Views)
Ok, I will try that
MikaelD
Message 7 of 10
(6,768 Views)
Is this a LabView or LabWindows issue?
Message 8 of 10
(6,738 Views)
Sorry I can see that I answered that I use LabView 2020 to A-Gus-Man earlier, but this is actually a LabWindows/CVI issue.
And my LabWindows version is 2011
So if you have any ideas on how to solve this, it will be highly appreciated.
\\ MikaelD
Message 9 of 10
(6,731 Views)
The error seems familiar but I'm drawing a blank right now on the exact cause.  I definitely have seen something like that after a partial/corrupt/incorrect download, so it is worth making sure the size and hash are correct on the target machine. Also, have you checked 32 vs 64 bit as suggested earlier?
Message 10 of 10
(6,717 Views)
