LabWindows/CVI
Problem with global variables passing with Labwindows CVI 5
Hello
I am trying to implement this in my program .. but assigning the Global variable is not working
NOTE: I am using LABWINDOWS CVI 5. (Old version)
/////***Test 1 contents****///
extern ViInt32 A= 0;   // Assigning  ‘0’  to Global variables
extern ViInt32 B= 0;
extern ViInt32 C= 0;
extern ViInt32 D= 0;
if (revision = =1)
A=Confirm Popup (“Verifiy”,"Does this unit also have hardware A”);
///*** end of Test 1 ***//
If I am trying the access above global variable to Test 5 or some other test program within same project
/////***Test 5 contents****///
If (A)
printf (“the Hardware mod is REV A”);
Else
Printf(“NO Hardware mod find”);
//*** end of Test 5 ***//
Now the query is whichever option (YES OR NO) in the confirm POPUP in Test 1. I am getting the output: “NO Hardware mod find”
The reason is the Global Variable is not passing.
Message 1 of 1
(4,548 Views)
