LabWindows/CVI
Problem with strcpy?
I have problems with these lines of code (most lines are omitted, but I hope
to make my point in the next few lines).
in panelHandle, panelHandleREGEdit;
char LUT_defaultfilename[19];
int main (int argc, char *argv[])
if (InitCVIRTE (0, argv, 0) == 0) /* Needed if linking in external
compiler; harmless otherwise */
return -1; /* out of memory */
if ((panelHandle = LoadPanel (0, "main.uir", PANEL_MAIN)) < 0)
return -1;
panelHandleREGEdit = LoadPanel (0, "main.uir", PANEL_REG);
printf("LoadPanel Status = %d\n",panelHandleREGEdit); // this prints the
value 12
// snip ...
value 12
strcpy(LUT_defaultfilename,
value 0
// snip...
RunUserInterface ();
return 0;
So it seems that using the function strcpy changes the integer
panelHandleREGEdit. Has there any bug been reported concerning strcpy, or do
I overlook something?
Kind regards,
Geert Van Doorselaer
(3,528 Views)
The target string was badly defined, making strcpy writing characters in
memory space of other variables.
Sorry for bothering you.
Kind regards,
(3,528 Views)
