LabWindows/CVI
Problem with the acquisition at more sampling rate
Hi all,
I am using the NI Fgen for signal generation anNI Scope for the measurement.
The frequency of the sine wave which i am goin to generate is from 100Hz to  1MHz.
So i have choosen 4M sampels/second. This can be generated by the FGEN and can read back from SCOPE.
But i am getting "Labview memory overflow" message.
The signal i am receiving will be of 4000000*2560 samples, which is a quite large number of samples.
I am getting the error message in the 4th or 5th iteration i.e. approximately after acquiring 4000000*5 samples .
Please give me a sollution so that the same error can be eliminated.
Thanks in advance,
Yogesh
Message 1 of 1
(2,942 Views)
