LabWindows/CVI
Problems by using multiple datasocket clients with just one Datasocket Callback?
Hello forum members,
I have a litte question regarding the use of the datasocket functionality.
I want to read out the html code of several urls.
Therfore I create an array of all the url's, which I would like to read out.
For every url I do the dsopen() function, in a for loop.
There I capture the handels of every datasocket which I had opened before.
In the callback function, which is specified in the dsopen function call, I would like to handel all the different datasocket calls.
Therfore I compare the handel which calls the callback function with my array of datasocket handels.
Now I found a little problem, that when I am open more than 3 datasockets I recieve an error message. "ERROR attempting ..."
And then the program stops.
Might it be the wrong way to use only one callback function for serveral handels, do I need to have a single callback for every single handle ?
Does anyone of you have some experience and could give me an hint?
Thanks in advance
Michael
(3,166 Views)
No, it is not incorrect to use one callback function for multiple datasocket handles. The error you are getting is probably related to establishing a connection to the website or downloading data from it. I am attaching my sample code that reads from 5 different web pages using a single callback function.
(3,156 Views)
