LabWindows/CVI
Problems embedding HTML into XML with CVIXMLSetElementValue - unwanted &lt and &gt
I'm using the CVI XML functions. When I try to insert some pre-exsting HTML as the element value with CVIXMLSetElementValue, it dutifuly converts all the HTMLangle brackets into &lt and &gt, which is NOT what I want.
(I can protect the XML integrity by wrapping it in [CDATA[ ....]] but that does not solve the conversion issue here.)
Any suggestions?
Ian
(4,898 Views)
To explain a bit further, below is a code snippet and the unwanted result that I see. Does this behavior - even with CDATA - make good design sense?
From my perspective CVIXMLSetElementValue should respect CDATA elements. Am I right? Or just biased?
stat = CVIXMLSetElementValue (test1_element, "Hello");
stat = CVIXMLSetElementValue (test2_element, "<p>Hello</p>");
stat = CVIXMLSetElementValue (test3_element, "<! [CDATA[<p>Hello</p>]] >");
// Problematic Output:
// <?xml version="1.0"?>
// <root>
// <test1>Hello</test1>
// <test2>&lt;p&gt;Hello&lt;/p&gt;</test1>
// <test3>&lt;! [CDATA[&lt;p&gt;Hello&lt;/p&gt;]] &gt;</test1>
// </root>
(4,851 Views)
Accepted by topic author Ian.W
The CVIXML code is just a wrapper over the Microsoft XML DOM (MSXML) ActiveX library. You can see the source code for this in <cvi>/toolslib/toolbox/cvixml.c. The behavior you are seeing is coming from MSXML. You may be able to find more information and possible workaround for this on Microsoft forums like MSDN.
(4,824 Views)
Thanks, Mohan. I have opted to access this HTML by always reading from the XML using the MS XML library, so it will all work out in the end. It took a small wrapper program, and adds a step to my development workflow, but it gets me past it for now.  But I might get ambitious and pursue your suggestion at a later date.
--Ian
(4,795 Views)
