LabWindows/CVI
Problems of DataSocket and EasyTab
Thanks Roberto, But actually i don't have WinInet.lib  in sdk/lib   is it winsdk?
Thanks again
--vishnu
Message 11 of 17
(2,192 Views)
I don't have \sdk\lib\WinInet.lib  and window.h and wininet.h in my CVI. From where i can get it?
Message 12 of 17
(2,191 Views)
Which version of CVI do you have? Standard or professional one? I always had professional version of CVI so I don't know if SDK was shipped also with base one in CVI6: in present version it isn't.
Supposing SDK was included in your package, have you installed it in your system? It can be installed during CVI installation but it is not part of standard process and must be explicitly selected: if you don't have installed it, you should be able to rerun installation program and add it to your system.
Message 13 of 17
(2,189 Views)
Thanks for help. I will try. But i don't have \sdk\lib\WinInet.lib . Can you help from where i have to get it or i need to purchase it.
--Vishnu
Message 14 of 17
(2,168 Views)
Dear Reborto, thanks for help. I have standard version. I will try to install it externaly if possible. I will see in my pack  it is available or not?
--Vishnu
Message 15 of 17
(2,166 Views)
Thank i got connection with FTP server.
Message 16 of 17
(2,014 Views)
Dear Roberto,
         Thanks for your FTP1.c program. I am using it. I fill that with WFTPD it is working very slow. In my application, i have used that for transferring 100mb data file and then display data point on screen. If am not using FTP and take data from local PC it is working fast but if i am taking data from remote WFTPD server, it is working slow.
         To check problem is in FTP server or Programming, i used "fileZilla ftp server". But this program is not working with that server. i don't know that this is program problem or what?
Please help me for fast FTP transfer.
--Vishnu
Message 17 of 17
(1,559 Views)
