LabWindows/CVI
Problems sending CVI 2-D array to vb.NET public multidimensional array using .NET controller
I have created a .NET controller to interface with CVI. I am passing a 2-D array from CVI to .NET, but am getting an out of bounds exception.
Does .NET handle multidimensional arrays in a different way? I looked into it and found that vb.NET allocates memory differently for multidimensional arrays.
I am using CVI .NET library functions to allocate memory, but am unsure why the arrays I'm passing are not being sent properly. Can someone shed some light
on this issue. Attached is my .c and .h file from CVI along with my instrument.
NOTE: Youll need to reload the instruments from the vb.net project and put the executable into the windows assembly GAC.
Message Edited by mdmorar on 08-31-2009 03:26 PM
Monil Morar
Control System Engineer
Secure Drilling Services (SDS)
Weatherford │ 16430 Park Ten Place │ Suite 200 │ Houston │ Texas │ 77084
(3,657 Views)
Accepted by topic author mdmorar
Try this. Sorry, not much commenting.
#include <cvidotnet.h>
#include "vbMath.h"
#include <cvirte.h>
static CDotNetHandle exceptionHandle;
static vbMathDLL_mathClass classHandle;
void init()
 double * result;
 double *myArray;
 int i,p;
 Initialize_vbMathDLL();
 vbMathDLL_mathClass__Create (&classHandle, &exceptionHandle);
 result=CDotNetAllocateMemory(sizeof(double));
 myArray = CDotNetAllocateMemory(sizeof(double)*5*5);
 for(i=0;i<5;i++)
  for(p=0;p<5;p++)
   *myArray = p;
   myArray = myArray +1;
 myArray=myArray-25;
 vbMathDLL_mathClass_addArray (classHandle, myArray, 5, 5, 5, 5, result, exceptionHandle);
 CDotNetDiscardHandle(classHandle);
 CDotNetDiscardHandle(exceptionHandle);
 Close_vbMathDLL();
int main (int argc, char *argv[])
 if (InitCVIRTE (0, argv, 0) == 0)
  return -1;    /* out of memory */
 init();
 return 0;
Imports System.Reflection
Public Class mathClass
    Dim globalVal As Double
    Public Sub addArray(ByVal array(,) As Double, ByVal x As Integer, ByVal y As Integer, ByRef c As Double)
        Dim i As Integer
        Dim p As Integer
        c = 0
        For i = 0 To x - 1
            For p = 0 To y - 1
                c = c + array(i, p)
    End Sub
End Class
Message Edited by craige on 09-01-2009 10:16 AM
(3,636 Views)
