LabWindows/CVI
Problems sending an Email from CVI
Sorry but I would like to post this question again because I have not been able to run this Function from CVI..
Hi!
As you know I have tried to use the Function InetSentMail() without success I don't know why this is failing, I have sent the Email from the CMD using the steps described by Shahina and I used the Outlook Sample to send the Email from CVI and it worked, But I can not have Outlook Installed on the all the Test Computers that we have, I would like to find out how to use the Function InetSentMail().
Is there something else to do in order to be able to have this function working properly?
Thanks for your support.......
(3,450 Views)
Hello Victor,
I think we could resolve this issue quicker if we corresponded through email. If you don't mind please email us at support@ni.com and in the subject line of the email please include "Attn to Shakhina Pulatova" and I will be happy to look into the issue further.
Thank you and best regards,
Shakhina P.
(3,416 Views)
Hi Victor,
We have recently learned that VirusScan version 8 might be blocking CVI from port 25 and thus InetSendMail function is failing (this works fine with VirusScan version 7.1). So if you are indeed using VirusScan 8, could you try uninstalling it and see if you can send email using the InetSendMail function?
Shakhina P.
(3,344 Views)
