LabWindows/CVI
Problems with GetTableCellValue
I created a table that the user must fill. When the button "Go" is pressed, I want to read the cells one by one and send the content to the RS232 port. But each time this error appears :
 NON-FATAL RUN-TIME ERROR:   "Interface_Profils.c", line 99, col 34, thread id 0x00000CF4:   Library function error (return value == -55 [0xffffffc9]). The index passed is out of range
It comes from the GetTableCellValue function... Can somebody explain to me what's the problem ?
Thanks!
CLA, CTA, LV Champion
View Cyril Gambini's profile on LinkedIn
This post is made under CC BY 4.0 DEED licensing
(4,243 Views)
What is the value that you pass to the Cell parameter of the GetTableCellVal function? Note that the indices are not zero-based but 1-based. The first Point index represents the column number (range: 1 to number of columns). The second Point index represents the row number (range: 1 to number of rows).
(4,240 Views)
Hello again,
I haven't tested it, but this piece of code should work fine:
GetNumTableColumns (pnlHandle, PNL_TABLE, &num_columns);
GetNumTableRows (pnlHandle, PNL_TABLE, &num_rows);
for (row_cntr = 1; row_cntr <= num_rows; row_cntr++){
        for (column_cntr = 1; column_cntr <= num_columns; column_cntr++){
                GetTableCellVal (pnlHandle, PNL_TABLE, MakePoint (column_cntr, row_cntr), string);
                num_bytes = ComWrt (port_nr, string, strlen (string));;
                if (num_bytes < 0){
                        MessagePopup ("Error", GetRS232ErrorString (num_bytes));
                        return 0;
(4,238 Views)
I attached my C code so you can see how I use. This code is very basic and not optimized at all...
(4,235 Views)
Thank you for your answer ! In fact I just inverted the rows and columns in the MakePoint function... THanks a lot for your help !
(4,232 Views)
