LabWindows/CVI
Problems with IDE paths ???
My very first posting. After 6 years of no C, 4 of which only G (LabVIEW), and last 2 totally idle, I am back on C with the CVI. I am trying to recall the stuff by going through the CVI Basics I & II course manuals. At the beginning - an obstacle! I cannot execute any of the course examples due to an error reporting "badly formed pathnames" or similar. The error msgs also contain strange folder hierarchy.
I have tried to reveal the right option containing the IDE paths but at no avail. Can someone help me set the paths correctly so I can compile and link successfully?
(3,219 Views)
Check under the Build->Target Settings... menu and see if the path to the executable you are building looks right. Be sure to check both the debug and release configuration.
Best Regards,
Chris Matthews
(3,219 Views)
