LabWindows/CVI
Problems with Microsoft Word while compiling with Labwindows
I'm having one problem, which doesn't affect a failure, I don't see one, but which is a little strange.
If I have opened a word document with headlines and index and start the labwindows compiler, the status bar at the bottom of word begins to update the index the whole time while compiling. Do you know why?
Br
Andreas
I'm using Labwindows CVi 8.5
(3,630 Views)
Hi Andreas,
i could not reproduce the error, which version of MS Word did you use ?
Could you post a screenshot and an example document to reproduce the behavior?
Best Regards
Benjamin
(3,599 Views)
Hi Benjamin,
I'm using Word 2003 SP3.
I'm not able to reproduce this failure at the moment. I don't know exactly which constellation I need. But my colleague also have (sometimes) this "problem". I will make the screenshots when it appears again. Maybe there have to be more software opened.
Br
Andreas
(3,571 Views)
