LabWindows/CVI
Process multiple files in a single loop
I am trying to harvest from data from multiple text files that I have in a folder.  Is there a function in CVI that could loop through the files that contain the data I need until it has gone through them all?  If not, all the files have a similar name (pucklocation.1, pucklocation.2, etc...).  Is there a way I could manipulate my cPath variable that I have when I call the functions below so that it does the first one, then increments to the next one, etc...
iIsGood = FileSelectPopup( "", "*.txt", ".txt", "Load", VAL_LOAD_BUTTON, 0, 1, 1, 0, cPath );
            if( iIsGood == 1 )
                iFileHandle = OpenFile( cPath, VAL_READ_ONLY, VAL_OPEN_AS_IS, VAL_ASCII );
(4,009 Views)
I suggest you take a look at GetFirstFile ( )  and GetNextFile ( ) functions, that permits you to iterate through a set of files on disk and get the name of each of them for further handling.
(4,003 Views)
Accepted by topic author neemtt
An alternative might be to use MultiFileSelectPopup instead of FileSelectPopup.
(3,953 Views)
