LabWindows/CVI
Program (Release x86) has stopped working on close
I discovered the problem in my application.  Turns out a menu handle was not properly deleted before being reused.   While a runtime message was valid, the message content of information was not helpful.   Thanks for all your help.
Message 11 of 14
(1,242 Views)
Hi Steve_Macha and ngay528,
I am glad we have been able to sort out your issue Steve_Macha. ngay have you been able to verify if this solution works for you?
Patrick H | National Instruments | Software Engineer
Message 12 of 14
(1,229 Views)
I did find 1 panel that was not closed properly, however, this was not the source of the problem, as I still get this issue randomly.  I'm currently looking into USB connections.  Since its random, I am trying to add different delays in case it is related to a race condition of opening/closing something.
Message 13 of 14
(1,224 Views)
Does unplugging and re-plugging the device usually sort out the issue on the next run of the program? After the issue starts does it persist for all subsequent runs of the application?
Message 14 of 14
(1,211 Views)
