LabWindows/CVI
Programmaticaly insert value on a ring control wich is inside a tab
I'm trying to programmaticaly insert values inside a ring control. This ring control is inside a tab.
If I remove the tab the InsertListItem() works fine, but if the ring is inside the tab I get an error message saying
"The control passed must be a list control."
How do I populate the ring control with data when the ring control is inside a tab?
I apreciate all the help.
Thanks in advance.
Daniel Coelho
Daniel Coelho
VISToolkit - http://www.vistoolkit.com - Your Real Virtual Instrument Solution
Controlar - Electronica Industrial e Sistemas, Lda
(4,003 Views)
Don't forget that the Tab is effectively a different panel with a different panel handle to the main one. Bear this in mind when you pass the panel handle and control identifiers to the control's library functions.
JR
(4,000 Views)
I can only add to JR answer that the correct panel handle can be retrieved using GetPanelHandleFromTabPage ( ) function.
(3,998 Views)
Thank you.
That is it.
I was using the wrong panel handle.
Thank you for the help.
Daniel Coelho
Daniel Coelho
(3,996 Views)
