LabWindows/CVI
Programme for SMC 100 newport rotation stage
I have been working on the shg(second harmonic generation). As part of experimental setup i have Newport single axis rotation stage. I want to control this stage using LabView.
The program should have step size and range of rotation. please help.
Thank you
(2,391 Views)
If you really want to control that device in LabVIEW then you have posted in the wrong board: this is the LabWindows/CVI board, while the LabVIEW one can be found here
(2,349 Views)
please suggest me where to post it so that i can get a response
(2,330 Views)
Did you happen to note the link at the end of my previous post? 😉
(2,315 Views)
If you want to change horse and use LabWindows instead, I've posted a C library to control the Newport XPS system, to be found on gitlab.
(2,305 Views)
