LabWindows/CVI
Programming Keithley's DAQ-Boards (DriverLINX)
I' m searching for programming examples which uses LabWindows CVI 5.0
and
the driver software DriverLINX (This software comes with the DAQ-Boards
from
Keithley) Can anyone help me?
(4,889 Views)
Hello Herbert,
I am not familiar with the DriverLINX driver and I think it might be helpfuler to contact the manufacturer of your device.
I still did some researches on the web. CVI is an ANSI C development environment and examples using this driver in C should compile in CVI. As it seem, the DriverLINX API is ment to be used with C++. I found an online document about this driver and CVI:
Using DriverLINX® Drivers with LabWindows/CVI
http://www.tek.com/sites/tek.com/files/media/document/resources/dlinx_cvi.pdf
If you need more information I would recommend you to contact the support of Keysight or the Driver's developper and ask if they have examples written in ANSI-C.
I hope this helps
best regards
______________
Florian Abry
Inside Sales Engineer, NI Germany
(3,646 Views)
