LabWindows/CVI
Programming NI PCI 1588
I know that .NET has a time library that allows you to create a time variable and then print it in several different formats.  I would assume that VC++ has the same.  Try to play around with the DateTime structure to see if it will do what you need it to.  You can find more on MSDN about it.
-Josh
Message 21 of 21
(1,043 Views)
