LabWindows/CVI
Programming PXIe-6682H in CVI in order to generate a PPS
HI everyone,
I' m working on a project that requests to program a PXI 6682H board in order to generate a PPS.
I started from an exmple provided by labview named "generate PPS and wait.vi" and I tried to implement the sequence of functions using the LabWindows/CVI functions.
That's the code I have written on CVI:
GetCtrlVal (timesynchtab, TimeSynch_Res_Timing_Synchro, TimSynch_ResName_6682H);
niSync_init (TimSynch_ResName_6682H, VI_FALSE, VI_FALSE, &TimeSynchro_6682H);
niSync_GetTime (TimeSynchro_6682H, &secondi, &nanoSecondi, &fractionalNanos);
niSync_CreateClock (TimeSynchro_6682H, NISYNC_VAL_PFI1, 1, 1, secondi, nanoSecondi, fractionalNanos, 0, 0, 0);
I expect a PPS coming out of PFI_1 but nothing happens,probably I've forgotten something but I don't know what it is.
Can anyone give me any suggestions on how to address this issue?
(776 Views)
It's always a good idea to add error checking to function calls: return code can offer useful informations to detect problems in the code or the system.
What I can tell is that there seems to be an error in the first line: TimSynch_ResName_6682H must be passed as a pointer in order to retrieve a value to use in subsequent code. On the other hand, if this variable is defined as a pointer then the following function calls must be tailored accordingly.
(750 Views)
Dear Roberto,
Many thanks for your quick and helpful response.
There was no problem in the first line since I was already passing a pointer, which I didn' t include in the first message in order to keep it cleaner, but your suggestion about adding an error check really helped me finding the problem in the function CreateClock(), and I solved it by simply changing the following parameters :
- high and low ticks;
- start time seconds,nanoseconds,fractionalNanos;
obtaining this -> niSync_CreateClock (TimeSynchro_6682H, NISYNC_VAL_PFI1, 100, 100, 0, 0, 0, 0, 0, 0);
I really appreciated your help, best regards.
(738 Views)
