04-08-2003 10:07 AM
04-09-2003
09:33 AM
- last edited on
10-08-2026
04:49 AM
by
Content Cleaner
Hello
If you are using CVI, you can use the Activex Controller to generated C based wrappers for the Windows Media Player activex control. Once these wrappers are generated, you should use the Visual Basic or C++ examples to get you started. Plus you should be able to find more documentation on the methods and properties on the MSDN
I hope this helps
Bilal Durrani
NI
