LabWindows/CVI
Programming the NI 9375
Sorry to resurrect a 3 year old thread that doesn't even belong here, but this is the only promising thread I have been able to find on this topic. Could you link to your post on the labview forums? I am having the same issue trying to communicate with both the DI and DO lines of the NI 9375.
Message 11 of 15
(2,641 Views)
Don't know how to link a post, and I'm not subscribed to the LV forum.  I solved this in LW programming in C.  Not sure anything I have done would help you if you are programming in LabView.
Message 12 of 15
(2,634 Views)
Alright, thanks anyway. I just added a second module to use one as DO and one as DI.
Message 13 of 15
(2,610 Views)
I am facing some issue while collecting data from digital input ports of Ni 9375, I am getting all data values as zero.
SOME INFORMATION-
I need to collect rotary encoder data of connected to servo motor.
Please look into my issue
Message 14 of 15
(1,773 Views)
Not sure the 9375 is the best choice or a rotary encoder.  You need something to cause an interrupt at the encoder data rate.  I use the 9375 just for control signals out and digital status in.
This is an example of my setup code:
// Initialize the Module A2 NI9375 16-Channel DI
// Note:  The DIN and DOUT tasks must be started before the Analog task is started, so that the DIN and DOUT tasks are
// known the first time the Analog interrupt happens.
// Create the DIN task
DAQmxErrChk( DAQmxCreateTask( "MbDasDigitalIn", &DinTaskHandle ) );
// Create Digital In channel defined as all 32 bits read at once
DAQmxErrChk( DAQmxCreateDIChan( DinTaskHandle, "MbDas-DIO/port0", "DIN", DAQmx_Val_ChanForAllLines ) );
DAQmxErrChk ( DAQmxStartTask( DinTaskHandle ) );
  SysLogEntry( "\Initialized Module A6 Digital Input Channels.  Started DinTaskHandle Task.\n" );
Sleep( 100 );
// Initialize the NI9375 16-Channel DO
// Create the DOUT task
DAQmxErrChk( DAQmxCreateTask( "MbDasDigitalOut", &DoutTaskHandle ) );
// Create Digital Out channel defined as all 16 bits read at once
DAQmxErrChk( DAQmxCreateDOChan( DoutTaskHandle, "MbDas-DIO/port1", "DOUT", DAQmx_Val_ChanForAllLines ) );
// Start the task
DAQmxErrChk ( DAQmxStartTask( DoutTaskHandle ) );
And then within an interrupt handler, this code:
if ( DinTaskHandle )
DAQmxReadDigitalScalarU32 ( DinTaskHandle, 0.0, &dinUInt, 0 );
*( unsigned int * )&Din = dinUInt;
That *( unsigned int * )&Din = dinUInt; writes the UINT into a bit structure.  One thing to remember is that while you read and write 32 bit integers, you are only interested in the lower 16 bits.
Message 15 of 15
(1,763 Views)
