LabWindows/CVI
Progress bar fill color
Dear All,
I use a progress bar in my CVI2017 project and I would like to change the default fill color to blue.
As far as I understood I have to disable the panel theme in order to make the color change effective but the fill color still remains the default (green).
Here are the relevant rows from my code:
ProgressBar_ConvertFromSlide (panelHandle, PANEL_PROGRESSBAR);
ProgressBar_SetAttribute (panelHandle, PANEL_PROGRESSBAR, ATTR_DISABLE_PANEL_THEME,1);
ProgressBar_SetAttribute (panelHandle, PANEL_PROGRESSBAR, ATTR_PROGRESSBAR_BAR_COLOR, VAL_BLUE);
What am I doing wrong?
(1,260 Views)
Hi
Try to disable the panel system them
SetPanelAttribute(hPanel, ATTR_CONFORM_TO_SYSTEM_THEME, 0);
Jan
(1,242 Views)
Thank you for the tip, I just tried it but it did not help.
(1,238 Views)
Accepted by topic author varta
Hi
Use  SetCtrlAttribute (panelHandle, PANEL_PROGRESS,  ATTR_DISABLE_PANEL_THEME, 1);
before ProgressBar_ConvertFromSlide();
Jan
(1,220 Views)
Hi
It works, thank you.
(1,214 Views)
