LabWindows/CVI
Project won't run in debug mode after I copy and rename it.
Hi Everyone,
I'm having a really odd issue where I copied a fully functional project folder and renamed it and now it won't run. For example, let's say my project folder's name was BCC5. If I copy the folder and change the name to TCC5 it will compile and build fine, but when I try to run in debug mode the UI panel won't come up and it gets stuck in a "Not Responding" state and I have to use task manager to exit LabWindows/CVI. If I run the TCC5.exe it'll work fine. If I change the project folder name back to BCC5 and rebuild it works as expected. Does anyone know what problem could be?
It doesn't doesn't even make it to the first line of the main() function before it crashes. I tried putting a break point there.
Dave
Message 1 of 1
(1,879 Views)
