LabWindows/CVI
PromptPopup
Hello
I would like to put a default text in a text string on a PromptPopup.
For example:
    PromptPopup ("Server Name?",
                 "Type the name of the machine running the sample server "
                 "application.\n\n(example: abc.xyz.com or xxx.xxx.xxx.xxx)",
                 tempBuf, 255);
In the answer text box, I would like to have 127.0.0.1 by default in the box, for my test, but the user can modify it to a real IP.
Is it possible?
Thank a lot, I work on CVI 8.5.0
(4,028 Views)
AFAIK this is not possible using standard CVI popup windows: you will need to create your own panel, customize it according to your needs and display it with InstallPopup.
(4,023 Views)
Thanks for you answer, I will use my own panel.
(3,999 Views)
