LabWindows/CVI
Pulse Dectection/Counter
Is there a function in the CVI Analysis library I can use to either detect or count pulses from an array of voltage values?
(1,426 Views)
You could try using PeakDetector () function and post process Peak Locations array to count the pulses
(1,393 Views)
