LabWindows/CVI
PulseParam Returns Negative Rise Time???
I am using the PulseParam library function to analyze a pulse in some acquired data. During one test, this function is returning a rather small (-1894) negative value for the rise time, on a positive going edge. However, the 10% and 90% amplitudes it returns are reasonable, as well as the returned value for the delay. If I slightly widen the range of data analyzed by the function, PulseParam will return values that are more reasonable, such as 64 for the rise time, with values for the 10%, 90% and delay that are the same as the values returned when the rise time is -1894 using the more narrow range of data.
Is this a bug or a feature? 🙂
David
Message 1 of 1
(3,286 Views)
