LabWindows/CVI
QNET SENSOR
Hi, I am junior student who learn about CVI.
My task on this month is to make the program which views the sensor data from QNET mechatronics sensor, NI ELVIS.
But I can not know how i can read the sensor data form QNET in CVI.
Which function should i use?
If you know, please tell me.
Thanks for reading 🙂
(I just can draw the strip chart from random data... )
(3,298 Views)
DId you unlock the material on the "Resources CD" that was supplied with the system? That contains sample VIs and documentation that will show you how to interface to the sensors.
(3,254 Views)
