LabWindows/CVI
Qt NIDAQmx Error with sample code DAQmxErrChk(DAQmxCreateTask("MyTask", &taskHandle));
I am using qt and the following import and include statements in my project file to link the library and the compiler
LIBS += "C:/Program Files (x86)/National Instruments/Shared/ExternalCompilerSupport/C/lib64/msvc/NIDAQmx.lib"
INCLUDEPATH += "C:/Program Files (x86)/National Instruments/Shared/ExternalCompilerSupport/C/include"
 When I build the sample code to obtain just some voltage samples, I am receiving an error
DAQmx Error: Internal Software Error occurred in MIG software. Please contact National Instruments Support.
Task Name: MyTask
Status Code: -229771
from the first statement
 If anyone has any ideas on how to fix this issue please let me know as soon as possible. I have attached screenshots of my project file and my main file for additional reference as well. Thank you in advance!
(1,585 Views)
you are mixing quite a few different things from what I see:
- C and C++
- QT and LabWindows (?)
- Windows (paths) and Linux/QNX
My (wild) guess is that the runtime does not initializes properly. For instance are you sure those paths should be in DOS syntax and not in Linux syntax ? Do you have ways to check how the niDAQmx library is loaded: via a (CVI?) runtime, a dynamic library or a static library. I'd probably run ldd on you executable and then run it with
strace -e trace=open
to see what's going on.
(1,540 Views)
