LabWindows/CVI
Question about parallel daqmx tasks on cDAQ-9188
I have a cDAQ-9188 chassis, housing four NI9203 modules.
I currently have two tasks which I wish to run under NI-DAQmx, one is acquiring 14 channels of analogue inputs (at 750 S/s) and the other is monitoring an encoder connected to the PFI inputs on the chassis.
I have configured the AI task to trigger an event every 75 samples, and I have configured this to be processed in the main execution thread.
I am using the execution profiler, and if I have the AI task running, the encoder task takes around 30ms each time to obtain a reading - it the AI task isn't running, this drops down to around 2ms which is much more reasonable.
Surely it must be possible to run these tasks in parallel without such a detrimental affect to the time taken to obtain an encoder reading?
What should I be doing to allow these tasks to run comfortably side-by-side?
Thanks for any help,
Chris
(3,270 Views)
Hello Chris,
I think it should well be possible but obviously there are a lot of variables here.
Could you possibly attach the code you are seeing this behaviour? I am happy to take a look and see if there is anything I can spot.
Also, this application is obviously dependent on the Ethernet connection, what is the context of this system in the network?
Best Regards,
Nick
(3,252 Views)
Hi Nick,
Sorry for not replying sooner, I've not been in at work.
I'm attaching some files which are a much stripped down version of my project.
In this cut-down version, the read encoder call takes approx. 10ms when the AI task is running and 1-2ms when it isn't, so it doesn't exactly duplicate my issue, but is representative.  The timings I'm quoting are obtained from the execution profiler.
Thanks in advance,
Chris
(3,237 Views)
