LabWindows/CVI
Question on force reboot with setup.ini in CVI Distribution Kit Installers
Hello Everyone,
I am confused with the random "force reboot" when finishing setup with DK installers these days. I have tried several times, and found that reboot warnings mostly come when system is running an independent CVI-based program during the installation.
Then I have reviewed this post. As you see, passing /r on command-line to setup.exe is a good idea, and it  indeed works, but what I need is an easier way for the one who will only use his mouse to double-click the setup file:(
So, is there any way adding a line in setup.ini to achieve it? Maybe it just likes "reboot=0/1" or something else.
Besides, here says "CVI's Distribution Kit functionality utilizes a third-party product called Instalit from HPI". Since I can't get any information on google about neither Instalit nor HPI, could someone tell me where I can find topics or APIs about this installer?Simple explainations of properties in setup.ini file are also welcome.
Many ThanksSmiley Wink
Message 1 of 1
(4,386 Views)
