LabWindows/CVI
Question regarding to tree control CVI
I am trying to use the GetTreeItemAttribute CVI function and get the check box state information from a tree and store in a array, but the compiler just gives me errors showing
NON-FATAL RUN-TIME ERROR: "Test.c", line 92, col 17, thread id 8188: Function GetTreeItemAttribute: (return value == -10 [0xfffffff6]). The control is not the type expected by the function。
the source code looks like following:
int panelID = 0;
int i;
int Mark_State;
char Flag[MAXNUMBER];
nullChk (InitCVIRTE (0, argv, 0));
errChk (panelID = LoadPanel (0, "test.uir", PANEL));
for (i = 0; i < MAXNUMBER; i ++){
       GetTreeItemAttribute (panelID, TABTEST_TREE, i, ATTR_MARK_STATE, &Mark_State);
       Flag[i] = Mark_State;
If possible, can somebody help me to take a look and see what is wrong with my code?
Thank you
(3,237 Views)
Accepted by topic author SilverMan
You named the tree control as TABTEST_TREE. If your tree is in a tab control you need to get panel handle of the tab. Tab pages have their own panel handles. This is the documentation.
Hope this solves your problem.
S. Eren BALCI
IMESTEK
(3,199 Views)
Thank you so much for the help! i didn't realize that TAB will need a different handler.  The problem is fixed.
(3,176 Views)
