LabWindows/CVI
Question with Function GetCompName();
I am having some trouble when try to use the 2013 CVI function.
in the main routine I include the hearder file of GetCompName();
#include "toolbox.h"
defined the variable with
char ComputerName[MAX_COMPNAME_LEN];
and in Main.c I just put GetCompName(ComputerName);
but I keep getting the error message:  error: Undefined symbol '_GetCompName@4' referenced in "f:\XXX\Test\cvibuild.test\Debug\test.obj".  everything is fine if I comment out the section of GetCompName(ComputerName);
Is there anything I missed?  Or is it because the system have compatible issue? I am using Windows 7 64bit environment.
(7,897 Views)
this function GetCompName() belongs to the Programmer's Toolbox, so you need to include the respective include file
include <toolbox.h>
(7,891 Views)
Hi Wolfgang,
Thank you for the reply, I did include the library before using it with #include "toolbox.h"
But the error remains.
(7,889 Views)
Accepted by topic author Silverwolfman
You also will need to add the library to your project. This can be done in two ways:
- Use the Library / Customize menu to add \toolslib\toolbox\toolbox.fp to your libraries
or
- Use Edit / Add Files to Project to add toolbox.fp to your project
(7,887 Views)
Thank you for the help!
That works.
(7,881 Views)
My pleasure Smiley Happy
(7,870 Views)
