LabWindows/CVI
Questions on control shortcut keys
Dear Roberto Bozzolo:
Thank you very much! Maybe I haven't expressed myself clearly. I'll try again.
first, I do put different shortcut keys for the different controls.
Second,I'll tell you what happened with my programm. I created several shortcut keys for command button.In my main panel, there is a timer control which ticked whenever possible.One "toggle" button to start and terminate a routine.I had setted one shortcut key for that button,but the shortcut keys can't work before I disable the timer control.And I created a command button to print out the result, another command button to save the data to hard disk.I had setted two different shortcut keys for that two buttons.Then I used one shortcut key to tiggered
one button,displayed a popup panel.When I return to the main panel, all shortcut keys can't work.If I click mouse button on the control except command button,such as a ring control,all shortcut keys work proprely again.
I will send you my UIR file.But I use chinese on the panel,I don't know fi you can display it correctly. Other more, the distribute kit seems not suport chinese,will you please give me some suggestions on that?
(2,967 Views)
Is this a set focus problem ?
Prior to returning to the main panel, do you have to set the focus back to the main panel ?
(2,967 Views)
