LabWindows/CVI
Questions on viRead
I used to use the function of "ComRd" to get a R232 response. For example, if I want to read 10 bytes from input queue of COM1 into buf, The command "n = ComRd (1, buf, 100);" could be used. And, return will be given on timeout or when 100 bytes have been read. Also I can set timeout by using "SetComTime."
Now I'm converting to develop COM Port communications driver by using IVI. In IVI viRead has the same role with "ComRd", however:
1, How to set Timeout in IVI?
2, Before getting expected number of bytes, viRead will keep reading until timeout ?
Thanks!
Jacky
(4,761 Views)
To set I/O timeout, use viSetAttribute() function.  The time unit is milliseconds:
vs = viSetAttribute( vi, VI_ATTR_TMO_VALUE, 3000);
viRead() will complete successfully when the specified number of bytes has been read, or when the specified Termination Character has been encountered.  When the specified timeout has elapsed before completing by num of bytes or by termination character, the viRead() will return VI_ERROR_TMO.
The following example reads a response string from instrument, it terminates when 256 bytes have been read or 0x0A byte (Line Feed char) has been encountered.
ULONG dwLen;
char sz[512];
vs = viSetAttribute( vi, VI_ATTR_TERMCHAR, 0x0A);
vs = viSetAttribute( vi, VI_ATTR_TERMCHAR_EN, VI_TRUE);
dwLen = 256;
vs = viRead( vi, (unsigned char*)sz, dwLen, &dwLen);
By the way, viRead() is a VISA function, not IVI.Smiley Wink
Hope this helps,
Makoto
(4,757 Views)
A little addition to Makoto good explanation.
Definitely YES: viRead is a syncronous function. That is: the function will not return control to your application until one of the following occur:
- Timeout
- Received expected number of bytes, or
- Received termination character
After the function terminates you will need to test return value and if not timeout handle the received message.
(4,750 Views)
