LabWindows/CVI
RT DLL general protection fault associated with serial I/O
I'm experiencing Generatl Protection Faults on my real-time PC running LabView Real Time 9.1.0.  The faults occur when oppening/reading/writing from a serial rs-232/422 port, regardless of whether I use the Serial library or VISA library.
How do I debug this? Is there a stack dump stored somewhere on the RT system when a fault occurs?
I am using LabWindows/CVI 2009 with the corresponding RT module to do my development.
ndo
Message 1 of 11
(4,509 Views)
Hi Ndo,
Please see the GettingStartedCVIRT.pdf.  You can find this under Start»All Programs»National Instruments»LabWindows/CVI version»LabWindows.  This includes information about ensuring you have CVI support installed as well as how to debug your application.
Cheers,
Message 2 of 11
(4,475 Views)
Hi Michael,
Thanks for the response.  When a General Protection Fault occurs, the debuger stops and does not give any details about the fault except for the line that caused it.  That is how I determined that the RS-232/422 comm was causing the problem.  I don't know how to dig deeper to find the exact cause.  On the Windows side, when a fault occurs, there is a stack dump that can be analyzed.  Is there a similar dump file on the RT?  What is the methodology to debug a crash on the RT?
--ndo
Message 3 of 11
(4,467 Views)
Hi Ndo,
Please take a look at this KnowledgeBase:  Is There an Error Log File for my Real-Time Controller?
Cheers,
Message 4 of 11
(4,447 Views)
Thanks Michael.  I'll give this a try.
--ndo
Message 5 of 11
(4,442 Views)
Michael,
I was able to get a report of the crash just as the KB instructed.
(Although no report was generated when I ran my DLL in debug mode, the report was only generated when I deployed the DLL to the RT system and a crash occurred. )
I've attached the report here, can you tell me why it's crashing?
ndo
Message 6 of 11
(4,430 Views)
Hi Michael,
Any update?
ndo
Message 7 of 11
(4,388 Views)
Update (in case anyone else is having the same issue):
I have narrowed down the problem to the RT Symmetric Multicore Processing Extension feature.  If I install SMP on my RT system, my software crashes (runs fine if there is no SMP installed).
Currently working with NI to identify the exact problem...
ndo
Message 8 of 11
(4,350 Views)
ndo,
Has there been any resolution to this?
Matt
Message 9 of 11
(4,108 Views)
Matt,
I've had no update from NI reagrding this issue.  I'm currently only using one core (no SMP).
--NDo
Message 10 of 11
(4,093 Views)
