06-21-2013 07:13 PM
How do I re-use CVI color settings, such as text color, background color etc., from previous version?
Used to be saved in windows register. Not working anymore.
Solved! Go to Solution.
06-22-2013 04:23 PM
If you are using a recent version of CVI you can use Import/Export Settings facility.
I don't remember which is the minimum version you can use it on, though.
