LabWindows/CVI
ReScaling IHM when monitor resolution change
I don't understand how to use other attribute in edit panel windows. I try to change
the resolution adjustement to 100% and I validate the scale contents (with Min Panel Height and Width to 0)
but when I execute the program, cvi answer me in a dialog box this message : "The attribute value passed is not valid"
and if i try to change the resolution (less than original), I can't execute my software because cvi load this message box :
"Unable to open user interface resource file "path .uir file" (the attribute value passed is not valid)"
Could you explain to me how to use this options and perhaps send me a sample for demonstration
With king regards
Patrice Collière.
Message 1 of 1
(2,757 Views)
