LabWindows/CVI
Read DI, from multi I/O port.
Hi, i'm using PCI-6229 on windows system.
I read correctly 7 lines of port P2 throws the following command:
DAQmxCreateDIChan(NITaskHandleDI,'Dev1/port2/line0:7',nil,DAQmx_Val_ChanPerLine);
DAQmxReadDigitalLines(NITaskHandleDI, 1, 10, DAQmx_Val_GroupByChannel, @NIReadDI, sizeof(NIReadDI), @NINumSampleRead, @NINumBytePerSample, nil);
Now, i would reading first 4 lines of port P1 and writing other 4 lines of the same port.
P1.0, P1.1, P1.2, P1.3 are input signal.
P1.4, P1.5, P1.6, P1.7 are output signal.
How i must configure the channel for reading and writing?
(1,437 Views)
To specify channels I guess you just need to configure the command like this:
DAQmxCreateDIChan(NITaskHandleDI,'Dev1/port1/line0:3',nil,DAQmx_Val_ChanPerLine)     for creating Digital Inputs
DAQmxCreateDOChan (TaskHandleDO,'Dev1/port1/line4:7',nil,DAQmx_Val_ChanPerLine)    for creating Digital Outputs
For more information, you can follow these links:
DAQmxCreateDIChan
DAQmxCreateDOChan
(1,316 Views)
It is to be said that you can't read and write at the same time to the ports with a single instruction, if this is what you are trying to do: you need a task for reading and a separate task for writing (with appropriate DI and DO channels as shown by Mr.Genius)
(1,309 Views)
And you can't mix and match DI and DO lines or ports in the same task either (for reading obviously, writing to a DI is anyhow impossible).
Rolf Kalbermatter  My Blog
(1,297 Views)
