LabWindows/CVI
Read Special Characters from String Input
I am Currently writing a small Tool grabbing input from a Barcode Scanner which scans a Datamatrix Code.
The Scanner is basically a keyboard emulator, so I want to use a string input in my gui. If I scan the Codes to an Editor such as Notepad++ I will see all the special Characters such as RS, GS and EOT (Ascii 29, 30 and 4). The String (and the Textbox) Control omit these characters which are extremely helpful when parsing the Scanned String.
I have tried different Fonts and Character Sets but none of this has been successful so far.
Does anyone have an idea?
Thank you and Regards,
Michael
(3,055 Views)
Accepted by topic author MichaelWerner
Since a colleague delivered a working Idea internally I want to share it here, too:
Using EVENT_KEYPRESS and GetKeyPressEventCharacter() solved the issue. It is a little bit more Code to write then just reading the Value from the string-Input after a Commit but it works fine.
(3,037 Views)
