LabWindows/CVI
Read Terminated Buffer bug in CVI 5.5 ? (2)
Another thing that make my headache to grow....
When I run the project inside CVI 5.01 IDE, it works but if I create
the .exe file, it stops working.
This is because the .exe file is using the CVI 5.5 RTE ?
If so, there is a way to make the .exe file using the old CVI 5.01 RTE
Ciao
Dimitri
(3,188 Views)
Dimitri
I also fight with different versions of the RTE, but I found no way to use
different version on one machine.
Once you have updatet to 5.5, I found no way to run an .exe file with RTE
5.0
Stephan
Dimitri Ghinis schrieb in im Newsbeitrag:
ap1mfso0a101sovnbu0j18rlcabbjpa46m@4ax.com...
> Ciao
> Dimitri
(3,188 Views)
