LabWindows/CVI
Read Terminated Buffer bug in CVI 5.5 ?????
Hi all!
This thing is causing me a terrible headache.
I have an application that read terminated buffers from a COM port.
The function waits for the 0xBB char (ComRDTerm).
The problem is : with CVI 5.5 it does not work!
My call is : iRet = ComRdTerm (COMM_CP, sBuf, 10, 0xBB);
but in CVI 5.5 the fuction ALWAYS read 10 chars without looking for
the end char.
After some time spent trying to find the bug (but I did not make any
changes in this part) I compiled the project back in CVI 5.01.
Result : it works!!!!!!
I had a look in the New/Changes section of the manuals but I found
nothing regarding this stuff.
What can I do to make CVI 5.5 read terminated buffer?
Or is a bug?
Ciao
Dimitri
(3,172 Views)
The first thing I must ask is: Have you configured and opened the port
before using this statement. I am using this function in my program,
all-be-it in CVI 5.0.1
Just in case you didn't, here is the procedure I used,
First open the port:
OpenComConfig (PORTNUM, "", 9600, 0, 8, 1, 512, 512);
Next Flush the port, just in case there is something there,
FlushInQ (PORTNUM);
FlushOutQ (PORTNUM);
Next install the callback,
InstallComCallback (PORTNUM, LWRS_RXFLAG, 0, 0x04, ComEvent, 0);
The header of the callback should look something like this.
void CVICALLBACK ComEvent(int portNo, int eventMask, void *callbackData)
Try this procedure and see how you go.
Richard
Dimitri Ghinis wrote in message
news:mm1mfsgi9jndqonpjl8t1jkhh39s92vd2b@4ax.com...
> Hi
all!
> the end char.
> Or is a bug?
> Ciao
> Dimitri
(3,172 Views)
